351M Problem
Old May 26, 2008 | 01:06 PM
trinogt's Avatar
trinogt
Yeah, especially if there is no flow...
Old May 30, 2008 | 09:45 PM
fleetbob1's Avatar
fleetbob1
Question ???
with the radiator mounted in the bed
the upper & lower hoses are reversed
would that make it overheat in 15 minutes ????
Old May 31, 2008 | 08:36 AM
trinogt's Avatar
trinogt
Maybe you need a reverse rotation water pump to accomodate that change?
Old May 31, 2008 | 01:07 PM
hollenjoe's Avatar
hollenjoe
Originally Posted by fleetbob1
Question ???
Don t really know why but yes it would, i had that problem and had the radiator exit tubes welded backwards, I think it has something to do with the dirction the waterpump sends the water preasure and the positions of the exits, I dont really know but my car did overheat due to that..
Old Jun 1, 2008 | 07:16 AM
fleetbob1's Avatar
fleetbob1
Im switching the pipes today
The more I think about it, the more I think thats the problem
Coolant enters the engine through the lower hose and exits the upper
there is no way air can get out of the system if its drawing coolant from the top of the radiator
Ill post later to let you know the outcome
Old Jun 1, 2008 | 06:11 PM
fleetbob1's Avatar
fleetbob1
well got the cooling system 1/2 done
Ill have to finish later in the week
did the honey do list today
Old Jun 3, 2008 | 10:27 PM
fleetbob1's Avatar
fleetbob1
Problem not solved --still overheats
no coolant comming out of thermostat housing when hot
im going to pull the heads this weekend and check the block passages and replace the head gaskets
what about the coolant plug on the mounting surface of the Aussie heads ?
does it need to be removed ?
Old Jun 4, 2008 | 07:47 AM
80broncoman's Avatar
80broncoman
You're joking right? You have got to kidding me. those two square holes on the head are where the coolant leave the head and go back into the block and then to the thermostate housing. At the back of the block plugs are fine but they MUST NOT be plugged in the front.
If the front has plugs then I think you have just found the problem.
Old Jun 4, 2008 | 11:59 AM
fleetbob1's Avatar
fleetbob1
Remember these are Aussie heads they were originally on Cleveland engines
with coolant flowing through the front of the intake
I cant remember if i popped the plugs out
But i know i blocked the front ports to the intake
Ill find out when I pull the heads this weekend
Old Jun 4, 2008 | 01:58 PM
80broncoman
I didn't even know those heads were like that.
I thought only the boss 302 heads had the head to block surface pluged.
You learn something every day.
Old Jun 4, 2008 | 04:18 PM
hollenjoe's Avatar
hollenjoe
Why dont you check your block ussing water preasure, maybe it has some pasages blocked...
Old Jun 4, 2008 | 06:58 PM
fleetbob1's Avatar
fleetbob1
I was thinking about that too.............
today i removed the t stat housing and turned the water pump ---no coolant movement
so something is blocked, either the wrong head gaskets, or some blocked ports
Ill remove the heads and spin the water pump again to see if i have flow through the block.............
I did clean alot or radiator sealer out of the block, replaced all the freeze plugs too.
Maby i missed some ports (doubtful)
Old Jun 4, 2008 | 09:04 PM
  #28
danlee's Avatar
danlee
Were those heads used on a Clevor motor?
A Clevor feeds water from the heads through the intake manifold, not through the block as with a 335 series motor.
Old Jun 6, 2008 | 12:36 PM
  #29
fleetbob1's Avatar
fleetbob1
I replaced the head gaskets last light
all ports are clear and gaskets were on right. head passages were good too
Im still stumped
later i will run the engine
I think i have a air pocket problem
Old Jun 7, 2008 | 01:31 AM
  #30
Colo79Ford's Avatar
Colo79Ford
One thing to try could be to temporarily remove the radiator from the bed of the truck, build a stand for the radiator, place radiator on the stand, in front of, and with the radiator cap just higher than your highest point of coolant flow for the engine and run it.
What is your "routine" for adding coolant to the system?
