Sponsored by: Real Truck
passenger window freezing?
Old May 25, 2008 | 12:23 PM
Lovebigtrucks's Avatar
Lovebigtrucks
2002 F250 powerstroke diesel super duty. my passenger window just started failing. all my windows work but every once in a while my passenger window wont roll up. if i keep clicking the button over and over it eventualy goes up.
what could be the problem? i would rather not take it in to be looked at when im sure i can fix it myself.
Old May 25, 2008 | 01:16 PM
Willyd88's Avatar
Willyd88
Switch?
Does it only have problems when you operate it form the drivers side switch? or passanger side switch? If so its probably the switch failing.
If it has problems when operating from either switch than its probably a loose connection at the power window motor, are a cracked or broken wire going to the motor
Old May 25, 2008 | 03:29 PM
Green Ford's Avatar
Green Ford
X2 Thats what to look for.
Old May 25, 2008 | 05:20 PM
Lovebigtrucks
would the power window motor be in the passenger door allong with the power locks ect.
Old May 25, 2008 | 06:41 PM
Green Ford's Avatar
Green Ford
Yep. Thats where you can find it. Do a search on here for door panel removal.
