Oil Pressure ,What should it be
Old 01-29-2002, 11:05 AM
oldblue18's Avatar
oldblue18
oldblue18 is offline
Old 10-01-2002, 01:36 AM
JJSammy's Avatar
JJSammy
JJSammy is offline
I have a 1992 ford ranger with a 2.3L 4cyl. I was having intermittent trouble with the oil pressure gauge jumping around. I removed the sender and hooked up a mechanical gauge. I read 20-30psi at 2000 rpm. This seems too low. The manuals say 40-60psi is the spec. After replacing the oil sender I have a stable reading of just over half way on the gauge. The engine doesn't sound like it has an oil pressure problem. The sending unit threads into the head toward the back of the engine. Is there perhaps less pressure at that point
then when the sending unit is closer to the oil filter. I got no where talking to the dealer. It just seems like if the pressure
not correct the gauge would indicate a low oil pressure condition.
The question is what should the oil pressure be if someone was to
remove the oil sending unit and thread in a mechanical gauge?
Any ideas?
Old 10-09-2002, 06:01 PM
96f150's Avatar
96f150
96f150 is offline
40 to 60psi is @ 2000rpm. If you have at least 10psi per 1000rpm, you should be in fine condition.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Oil Pressure ,What should it be
