Archived Oregon Buy/Sell/Trade ADs
#106
just wondering if anyone has 1/2 ton disc brake 44 knuckles they dont need anymore that i could have
and i have a set of ranger tires and rims see pic for rims
a 94 f-250 transfer case manual
trade or sell\
trade or sell\
#107
If anybody needs a dana 24 divorced t-case out of a early 70's f250 4x4 i have a good one. Its a little dirty and has surface rust but it would clean up. I wouldn't want much at all for it. I have the case the mounting brackets, most of the shifter pieces, ( minus the shifter handle) and the floor pan from the truck it came out of.
Also I have a 4x4 4-speed out of a 1972 ford f250 4x4. once again everything is there minus the shifter.
If anybody is interested let me know
#109
1962 Ford 223 I-6
I have a good running, currently installed 223 in 1962 Unibody. Doesnt smoke, sounds tight. If someone is seriously interested I'll do a compression test. Includes oil bath air cleaner, generator bracket but not generator, bell housing clutch and flywheel, and most anything else that is attached. $150. Also have the radiator which looks very good. Compared the 62 6 cylinder rad to a 64 8 cylinder and they look the same except the mounting flange of the 6 is set toward the back a little. $75.00.
#110
ok im looking for a 73-77 f-250 4x4 frame and running gear for cheap i going to put my 71 f-100 body on it trying to do this cheap but if you need work done or help i could do that in exchange
also im looking for an apprenticeship in the automotive feild i already have a lot of experience looking for more
#111
WANTED: V8 Radiator 53-56
Looking for a v8 radiatior for my 53. I have 2 straight 6 radiators and I dont think they have enough cooling capacity for my SBC. I want ZERO over heating issues....if I cant find one used, I will have to buy new. Just would rather put the money in other parts of the truck. Let me know what you have?
Thanks
Thanks
#112
Have stuff and need stuff....
I have striaght rust free sheet metal for 65/66 F100 trucks you know what fits what send me list with needs. I will have a complete p/s setup for the 65/66 truck ready soon as I am doing a crown vic swap. Will also have the disc brake stup as well.
what I need:
16 or 17 inch ford wheels for pass. car bolt pattern
rear axles from a full size late 60/s ford 9in. with drums and backing plates
64/65/66 mustang bucket seats good core seats are fine
c6 to go behind a fe motor, have complete 4 spd to trade
ranger gas tank from a carb truck
I am still looking for a tow truck, nothing fancy the word is cheap here as I need it for personal hauling
Thanks guys.....
what I need:
Thanks guys.....
#113
what I need:
Thanks guys.....
what I need:
Thanks guys.....
#114
welll
when are you wanting the stuff, I put an offer in on a new house with a BIG shop and may be moving soon meaning the project is on hold for a bit, if you are in no hurry the better, other things I am needing would be a 5spd tranny to put behind an fe motor, or ???
#116
I have a 9in 3rd member and axle shafts they are in good condition $50 for the 3rd mem and $50 for the shaft or 30 each shaft will trade for 74-79 f-150 front suspension and brackets
