Why not consider running this puppy by your favorite autoparts store, for a no cost, in vehicle, electrical system check up, via their portable electrical system tester.
Properly used it'll likely sniff out your problem.
Before you go, you might double check the B- body ground lead/s from the battery, especially the ones to the radiator support, as thats where the head lights get their ground point.
the 3g is so simple to rebuild if you don't force the case apart.
Further more, you can just remove the regulator/brush holder from the back of it, with the torx screws removed. Pin back the new brushes and stick the new regulator in, tighten the screws, and pull the brush pin, and install back on vehicle and your done..
the diodes are probably ok, the diodes are one way switches that allow current to flow out of the alt, and not back in.
