New from Chile
Old May 24, 2008 | 12:49 AM
DRodgers's Avatar
DRodgers
New from Chile
Hi. I am a missionary (Canadian) living in Chile. I recently sold my 1971 F-100, (not too much rust problems here!) and bought a 1996 E-350 Powerstroke. I have a drive shaft problem and am wondering where I can ask for help on it?
Old May 24, 2008 | 01:05 AM
DRodgers's Avatar
DRodgers
New from Chile (2)
Better if I give some details. When I bought the van, I found that it had damage at the aluminum casting where the drive shaft slides in. The frame member supporting the casting was bent up about 2 inches, and the casting had been welded. We straightend the frame member, put in a new bushing, but it lasted little time before the bushing heated up and seized. Looks like no lubrication getting to the bushing. How is the bushing lubricated? Is there an internal duct coming through the casting, that might have been blocked when it was welded? Thanks for any help! DRodgers
P.S. it is a E40D transmission
Old May 24, 2008 | 09:15 AM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site!
The place for help is in our tech forums. Click on the Forums tab at the upper left and scroll over the boards. You can try here: 1968 - Present Full Size Vans - Ford Truck Enthusiasts Forums There is a board for transmissions that you might want to try and another for your engine.
Hope this helps.
Old May 24, 2008 | 11:31 AM
DRodgers's Avatar
DRodgers
Thank you, Dan
Frank1950
New Member Introductions
May 9, 2008 11:37 AM
bigviggs
Mar 3, 2008 07:29 PM
tom wedeking
Oct 21, 2007 10:01 PM
Jimmiek
Sep 11, 2007 09:31 PM
kds0216
Jul 20, 2007 08:18 PM
