90 tailgate
Old May 24, 2008 | 12:14 AM
86F150302's Avatar
86F150302
90 tailgate
My friend has a 90 F150 and I took my tailgate off and put his up too my truck and it looks like the lower brackets are the only thing I would have to swap to put a 90 tailgate on. Is this true? I like the smooth look of the 87-96 gates.
Old May 24, 2008 | 01:03 AM
big hoss 29's Avatar
big hoss 29
IIRC, the latch system on the 87-96 tailgate is different than the 80-86 tailgate, so you'd have to do some modifying to make it work right.
Old May 24, 2008 | 09:56 AM
86F150302's Avatar
86F150302
Do you think it would be worth trying to do?
Old May 24, 2008 | 10:24 AM
big hoss 29
I think it'd be worth trying. Anything can be done with enough patience and ingenuity. If man designed it, then man can improve it.
Old May 24, 2008 | 10:50 PM
Sycostang67's Avatar
Sycostang67
I did that swap once, it's not difficult but it's not as simple as swapping parts either. You have to drill new holes for the striker bolts to mount, and the lower brackets aren't interchangeable. The bolt holes aren't the same distance apart, but they are close. I just mounted the brackets using the top bolt hole, and then used the largest bolt I could find that would fit through the lower holes and put a nut on the backside. It worked just fine until I went with a newer bed as well and transferred the tailgate over to it. I may have a few pics of the swap I could send you if you like.
Old May 25, 2008 | 12:27 AM
86F150302's Avatar
86F150302
Yea I would love some pictures.
Thank you
Old May 25, 2008 | 02:55 PM
Sycostang67
PM me your e-mail addy and I'll send you what I have.
Old May 26, 2008 | 04:30 PM
nflfreak43's Avatar
nflfreak43
Im thinking of doing the same thing because my tailgate doesnt hardly ever open cuz its been bent so when u do this would there be any chance u would put some pics up?
Old May 26, 2008 | 05:03 PM
86F150302's Avatar
86F150302
Thanks for the pics. Ill be looking for a tailgate now. Doesn't look to hard to do.
I would add more to your reputation but it says I cant give you any more.
Old May 26, 2008 | 05:08 PM
Sycostang67
No problem, hope they help you out. The hardest part really is picking the spot to mount the striker bolts. I sat in the back of the truck and held the tailgate in place where I thought it should sit when latched and eyeballed where it should go then marked it with a marker. I made the hole a little bigger than needed to give me some room for adjustment as well.
Old Dec 30, 2008 | 12:48 PM
jschwen73's Avatar
jschwen73
Any chance of someone posting pics of this swap? Would be greatly appreciated! Also, can the lower pivots mounted to the truck bed still be used or do they have to be swapped out as well? Thanks for any info...
Old Dec 30, 2008 | 04:41 PM
nflfreak43's Avatar
nflfreak43
YAY! someone used the search feature and it worked im assuming. but i know there is someone that did this. i dont remember who though. hopefully for you they will pop up.
Old Dec 30, 2008 | 05:37 PM
jschwen73's Avatar
jschwen73
uhh, yeah the search function works if you have the time to wade through 14 pages of hits for the words "tailgate swap" then filter it for your specific application...
Old Dec 30, 2008 | 06:06 PM
Franklin2's Avatar
Franklin2
Here's a useful hint that helps me. If you plug in "tailgate swap" the search will bring up posts with "tailgate" and also posts with "swap". So this will bring up tailgate swaps, engine swaps, rearend swaps, cab swaps, etc. What helps(but is not perfect) is put in "+tailgate +swap" with a space between +tailgate +swap. This will include posts that have the word "tailgate AND the word "swap" both.
Old Dec 30, 2008 | 06:27 PM
jschwen73's Avatar
jschwen73
@ Franklin2
thanks for the tip...yeah I forgot that some forums allow wildcards that help you filter out hits...will remember that one for next time...Thanks!
