General Diesel Discussion
Battery Draw
Old May 22, 2008 | 01:00 PM
Dealership's Avatar
Dealership
Battery Draw
We've got a 1999 F350 Diesel, the batteries keep going dead after about 4 days. We have checked for a draw-no draw.We have replaced the batteries 4 times-the last time with Ford batteries, we have replaced the glow plug relay. Any ideas?
Old May 22, 2008 | 01:10 PM
wwb's Avatar
wwb
If you've done it correctly, and you're dead certain that there's no draw, then there's only one other thing I can think of that would cause batteries to go dead in 4 days.... no charge.
First, key on but engine not running..... is the little red "idiot light" with the battery symbol lit? (We're checking the bulb here). If you have a light, start the engine..... it should go out. If it goes out, that would indicate that it's charging, but I'd put a DVM on the batteries to be sure. Should be about 13.8 V until the glow plug relay drops out.... then, it should be close to 14.5 V. If the voltage isn't up there, then the alternator isn't working properly.
Old May 22, 2008 | 04:44 PM
Dealership's Avatar
Dealership
We have checked all of this. It seems to happen with key off position, and everything turned off
Old May 23, 2008 | 12:32 AM
randomhero1172's Avatar
randomhero1172
This is dumb but...maybe your alternator is running 100% - so the batteries dont die in a day, but slowly lose charge over time? just a possibility i guess. Also - one time in my grandmas caddy (91) the blower motor was stuck on due to a relay. check your relays and fuses.
Old May 23, 2008 | 06:24 AM
Kwikkordead's Avatar
Kwikkordead
I would have looked at other things than batteries on the first set of new dead batteries.
Have you checked the voltage at the batteries, key on engine running?
Alternator wave form correct?
jgossage
2004 - 2008 F150
Nov 28, 2015 10:42 AM
sanger440
1997 - 2003 F150
Aug 2, 2014 03:14 PM
Yoam69
Apr 7, 2014 10:35 PM
kornfanjoe
Oct 21, 2013 07:26 AM
BIGRNU
Nov 2, 2005 05:46 AM
