Heads
Old May 21, 2008 | 09:47 PM
joestratton1's Avatar
joestratton1
Heads
have a 84 F250 2v 5.8w
motor runs well, but is a little tired and slow. was thinking about a valve job, but called around and they want 1/2 million for a valve job these days. i see aluminum heads on craigslist and ebay new in box for 600-1000. has anyone tried any of these? motor is all factory EEC IV, and all working. wanting a little more performance but not sure its worth screwing with a truck that passes smog
any advice?
Old May 21, 2008 | 10:02 PM
Franklin2's Avatar
Franklin2
Do you have the variable venturi carb? Since you have the computer type engine and need to pass smog, I would not mess with it. That system gets good fuel mileage, but getting rid of it would give you a performance increase. I don't see much point in running higher flowing cylinder heads with the lousy 2bbl or even worse, the venturi carb.
Old May 21, 2008 | 10:33 PM
joestratton1
not sure if it is venturi carb, is electronic advance distributor.
mileage not so good 10-11 i want 14-15
think i could install edelbrock intake - four barrel - headers - without pissing off the computer?
