trans problem
Old May 20, 2008 | 10:22 PM
sadmnk's Avatar
sadmnk
trans problem
have a 93 150 with i belive a a4od has 14 bolts on pan. one of the cooler lines got a hole in it and started to leak.for a temp. fix cut out and put a piece of hose on it. now it will go into reverse and drive but will not shift out of 1st.when you let off gas it feels like its in nuetral,you dont get the drag as if you had pulled it down into 1st. it shifted fine when i parked it to fix the line half hour before. the transmission was rebuilt 3 years ago and have had no problems till now anybody have any ideas. its the top line on the side of the tranny.took off the line to see if it was plugged up but nothing. fluid is full
Old May 21, 2008 | 07:52 PM
subs1000w's Avatar
subs1000w
have you made sure the cooler isnt clogged although if it is your probobly to late
Old May 26, 2008 | 06:35 AM
96f150's Avatar
96f150
I'll second a clogged cooler.
Rich
rapidroy5858
Jun 25, 2012 09:53 PM
USMC0351fordtruckin
Nov 8, 2011 09:34 AM
