vibration and ?
Old May 20, 2008 | 11:26 AM
stickinnc's Avatar
stickinnc
vibration and ?
Hello, I just bought a 1990 ford f150 4x4. When going to disengage the 4 wheel drive do I have to drive in reverse to make it disengage? Also there is alot of play in the sterring colom and the truck vibrates bad when going 50 mph. The steering wheel i can move side to side about 1 inch both ways. What are your thoughts on this?
I will basically be using this for hunting and just around my small town. It snows here in the winter and I use the 4 wheel drive alot.
Old May 20, 2008 | 03:31 PM
Paul T's Avatar
Paul T
Do you have automatic hubs or manual? If you have automatic hubs you have to back up.
As far as the vibration goes, it could be bad tires, bent rims, bad universals, loose steering linkage, worn out steering box, bad tie rods, etc.. I would check the whole front end.
Old May 20, 2008 | 03:36 PM
stickinnc's Avatar
stickinnc
yes I have automatic hubs, thanks for the other info
Old May 20, 2008 | 09:31 PM
flareside_thunder's Avatar
flareside_thunder
the steering is not that sloppy mine moves about the same......I second what Paul said.
JR
jackpiner57
1997 - 2003 F150
Mar 2, 2010 11:51 AM
BroncoPimp94
Feb 9, 2010 06:45 PM
Mr.Russell
2004 - 2008 F150
Aug 7, 2008 10:20 PM
pbutland
1997 - 2003 F150
Jan 13, 2008 02:25 PM
daytoncobra
1978 - 1996 Big Bronco
Feb 11, 2001 09:03 AM
