Explorer front hubs always engaged?
Old May 20, 2008 | 08:13 AM
Stone Mathews's Avatar
Stone Mathews
All,
I had the front end on a 1998 Explorer 4X4 jacked up checking for play in the ball joints, etc, and when I spun the tire I noticed that the axle spun, and the front drive shaft spun.....
On my F-250, the only time the axle will spin and the front drive shaft will spin is when I have the manual hubs locked in.
I know the Explorer is not in 4X4 and the little dial on the dash is in "Auto" and not "4X4 high" or "4X4 Low", however, does that mean that the axle and the front drive shaft should turn? Seems like it would put unecessary drag on the transfer case and drive train when you are not in 4X4.
Thanks all!!!!
Stone
Old May 20, 2008 | 10:01 AM
mrshorty's Avatar
mrshorty
On 2nd gen Explorers, there is no disconnect at the wheel, so the axle will always be spinning with the wheel. On '95 and '96 models that have 2H/4A/4L settings, there's a vacuum actuated "center axle disconnect" in the differential that unlocks the diff from the driveshaft. On '97-'01's which have 4A/4H/4L without a 2H setting, the CAD is not there and the front drivetrain is always live.
Old May 20, 2008 | 02:24 PM
Stone Mathews
Very interesting.
Thanks Mr Shorty!!!
Old May 20, 2008 | 03:36 PM
freesplorer's Avatar
freesplorer
I have a 2001 xlt 6cl and has auto which is 2 wheel rear and the front kick in when the rear slips .... 4H and 4L
Where did 4A come in to the picture?
Old May 20, 2008 | 10:35 PM
mrshorty's Avatar
mrshorty
Sorry. 4A is my shorthand for the auto 4wd feature you just described.
Old May 20, 2008 | 10:51 PM
Bear River's Avatar
Bear River
Former ******
It is really AWD with a lockup. You always get power to all the wheels, and when slippage is detected, the differential will lockup to correct it.
greenman0013
Feb 20, 2017 08:32 PM
Nabors
Oct 7, 2012 10:19 AM
Dorosko
Nov 23, 2011 01:34 PM
trukerdanz
1997 - 2003 F150
Oct 18, 2009 09:50 PM
fordxl68
Offroad & 4x4
Oct 21, 2005 05:36 PM
