1973 ranger charging system issues
Old May 19, 2008 | 10:52 PM
1973FordRanger4X4's Avatar
1973FordRanger4X4
Unhappy 1973 ranger charging system issues
recently the alt light on the dash has illiuminated and the battery went dead. I then replaced the battery, altinator, and regulator with brand new ones. But the altinator is still not charging the battery and the veichle dies after the battery power has been used up. please post any ideas on wat could still be causing the problem.
Old May 19, 2008 | 11:02 PM
ford390gashog's Avatar
ford390gashog
Check the fusible links in the harness.
Old May 19, 2008 | 11:05 PM
1973FordRanger4X4
Talking stupid question
and where would this be and wat would it look like? and how would i test it?
Old May 19, 2008 | 11:11 PM
ihateminimumwage's Avatar
ihateminimumwage
I'd recommend buying a digital multimeter (they're like $30 at Radioshack, and are great to have in general). Then you can know exactly how much charge or drain you have going on.
Here's a thread of the hell I went through with my charging system from a while back (I too replaced EVERYTHING and kept having problems),
https://www.ford-trucks.com/forums/6...roblem-be.html
Franklin2 is the man when it comes to walking you through electrical problems. Read through that thread, there are all the tests you'll need to perform in there.
