Oil pressure
I noticed that the oil pressure in my truck dropped to almost 0 psi.
When I start the truck from cold, the pressure is up about 50 psi but after driving a while, it drops below 30. The longer I drive the lower it gets.
I suspect the guage is bad since its a cheap Walmart set but I checked into it anyway.
The line is run to the front driverside of the block above the oil pan and behind the fuel pump.
I removed the fittings, cleaned the orfice, reinstalled them with teflon tape. Then I went in the truck and removed the line behind the guage, started the engine and pumped about a 1/4 pint of oil from the line and no globs.
The engine is what I think is a 292 and was wondering if there was anywhere else to tap into the oil system closer to the pump.
I found a plug just above the pump on the drivers side but wasn't sure if this is the place to use or not.
Any help out there.
Thanks Charles
I noticed when I pumped the line into the cup that the oil is really thick. It was changed two days before I bought it. (the sticker is still on the winshield) the pressure from the line was like puoring tea in a glass. I figured it would be "shooting" out of the line.
Any more info would be helpful.
When you purchased this unknown motor, (new oil change or not) I would of ran tropartic thru it a couple of times at 500 miles. you have to realize that this motor is over 30 years old, and I don't even know its history.
Low oil pressure has 2 different directions.... 1 being that lots of motors dropped to 7 lbs after warmed up, and thats all it took to keep the idiot light off.
2 i wouldn't actually trust that walmart guage, but your mains could b shot, and thats why they "changed the oil 2 days before you bought it". fresh oil may hold pressure for a while until it limbers up......
What weight r u using.... I would b using 20-50 or straight 30 depending on how cold it gets there, and then watch your oil pressure gauge...
Hope this calms the nerves next time u r out and about
I had an "Y" block that when the oil level was low the pump would actually cavatate when turning... light would come on at any speed, during a turn and scare the hell out of you, but it was good the whole time.
Wayne
Has anyone heard of a high volume oil pump for the Y-blocks? I was also thinking about adding an oil cooler to help keep the oi; cooler thus increasing the pressure and keeping the mains lubed. I know the mains are getting oiled but I get very little on the rockers.
Any suggestions?
Krosati
