fuel leak in gas filler tube
hello guys, i have a big problem , 95 4.9 leaks gas thru gas filler tube, he'res the thing , it only does it when temp in atmosphere is 100+ deg ( its vegas) i changed vacumm solenoid, charcoal cannister, fuel pump cause it was bad, and gas cap,and it is killing me bad need help with summer coming, because in the winter time problem is non existent, PLEASE HELP GUY IM AM DESPERATE, ANYTHING HELPS, THANXXX!
im almost sure its in evap problem , im going to change the check valve in the gas tank and reroute a hose all the way to the charcoal cannister just to make sure ihave a no pinch lines or messed up or britle hoses , but like i said it leaks thru gas cap only when its 100 plus degress weather , i make a right and gas goes thru gas cap , i dont even touch the cap and you can hear the hissing , like gas evap trying to get out anywhere . now, is it true that those pressure valves dont get messed up at all , ? thats what a friend at ford told me , please comment or if you got any more info , please let me know thanx!
