STGs Minions general purpose thread. Giggity Giggity.
#61
Evening minions. I was busy over the weekend. I got my 2 1/2" leveling kit on the superduty with the 35" Cooper STT's. I left my pics at home in the camera. I will get my wife to email them to me so I can post up. I used the shackel lift off of ebay. It wasn't too bad to install.
I had to come back to Texas yesterday for some schools.
#62
You just need to make sure you get the right block. A D1ve block like i have is really only good up to around 800hp, then you need to add some hardblock to strengthen the bottom end. I believe the D0 block is the the better/more desired block, I can't remember the casting number, but it is the early 70's block which is getting harder to find.
#63
The D9 block from heavy trucks is the high nickel content block with the taller deck. Generally speaking I think its the most desireable big horsepower big stroker block. Some can be bored out .100 (thats .100 over not .010) and handle a 598 stroker crank.
you go through 10 blocks to find one and the sonic check and xrays cost more than just buying an eliminator or svt block.
#68
Whats up Harry. Is the SC chapter missing me?
George is primer green and surface rust is poping out in some spots so I take OD green spray paint and touch it up from time to time. I guess eventually it will be camo. Im going to take it to Maaco or something like that one day for a el cheapo paint job.
Is that the first time youve seen the truck? Visually it really hasnt changed much in the past 2yrs.
#72
100hp 4 cylinder outboard, but close in power anyway
stupid thing started, and I shut it off, and then it was locked up. this would be why. Oh well, some scrap aluminum now.
#75
Can't say that I've ever seen that, but I bet it would make a racket at 7000 rpm when it lets go. Worst carnage I've ever had was a dropped valve and a smashed up head. Some new springs and a rebuilt head and I was back on the road.
