what are my options if any I have a 1979 f259 400 with a dana 60 front the only headers I found were headman with fender exit. Has anybody used them and is there any chasis exit ones out there that will fit.
I'm sorry dude but that was hard to read. Please learn to put in punctuation.
I never passed english in school
I was asking if there are any other headers to put on a 1979 f250 400 motor with a dana 60 front end. I only see fender exit headers that headman make. there chasis exit headers will not fit with the dana 60. I am looking for full length headers. thanks
I have hedmans on my 78, They are a tight fit. I had to lift the motor, and cuss a little, but they fit without trimming. I do have a dana44, but I don't see how the 60 would make much of a difference, since the headers don't run near the axle. If you cross your exhaust over for a single exhaust, the front driveshaft would be in a different place, but that should be easily accomodated by a good exhaust shop!
for some reason the books say will not fit with a dana 60 front end. It might be because the shock mounts are in a different location than a 44
Problem I had with full lenght headers on my was that they ended up exiting dead center of the trans cross member about 2 to 3 inch away. That why I went with the shorties. I still have the full lenght ones in the garage never started the motor when they were on.
Bigpern2 is right they where a tight fit, I also had to undue both motor mounts and jack the motor up to get them in. One side of them came with in a 1/8" of touching them frame rail. The full lenght one I tried was Hedman Hedders 89216
