05 expedition console help
Old May 19, 2008 | 07:54 AM
wb_exp's Avatar
wb_exp
i had a eclipse nav unit installed a while back and the shop forgot to hook the lighter back up in the top of the console, under the radio. the one on the right side of console is working. i dont feel like taking back in for this. i removed the lighter bezel thinking the wire would just be there and i could plug it back in.....nope. how do you remove the console in this vehicle. i don't want to break anything.
thanks
Old May 20, 2008 | 02:04 AM
258exp's Avatar
258exp
There is a single screw under the rubber pad in front of the coin dispenser. The rubber pad may not appear to be removable but it is.
Old May 20, 2008 | 02:18 PM
JLMoreno911's Avatar
JLMoreno911
yes, like stated by 258exp, it is that simple...remove the rubber pad to reveal a single screw, I believe it is a 7mm screw. once you take that off you just pop the rest off...it is just held in place by clips...
