Interchangable front end?
Old May 19, 2008 | 07:26 PM
LiftdFord's Avatar
LiftdFord
just picked up a set of doors off the same truck today.. 1990.. no pw or pl so will it bolt up? the door panel is different in the '90 than in my '80
Old May 19, 2008 | 07:37 PM
ri_truck_guy's Avatar
ri_truck_guy
The doors will bolt on. The dash line on the door panels will be a little different, but the panels are also interchangable.
Old May 19, 2008 | 07:42 PM
rmalottwtes30's Avatar
rmalottwtes30
Originally Posted by ri_truck_guy
Anything from 80 to 96 will fit, but the wheel wells will be slightly different on the 87-96 beds.
Thanks, For some reason I kept thinking the cut off line was 91...Well it makes it better cuz I know where to get a great bed now...
Old May 20, 2008 | 10:48 AM
Sycostang67's Avatar
Sycostang67
I have '90 doors on my truck with the '90 panels. The lines dont match the rest of the interior, but it's pretty close. No one even notices until I point it out.
Old May 20, 2008 | 12:15 PM
travisg96's Avatar
travisg96
Will the fenders and grill from a later F-250(1989+) fit on a 1986 F-250 or will the headlights not work because the cowl is different?
Old May 20, 2008 | 02:38 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Not by themselves no.
As said earlier in this thread, you need to use the whole front clip.
Old May 26, 2008 | 07:07 PM
80F100man's Avatar
80F100man
Syscostang67,
I like the stacks you have , what size are they, 3" i.d. or bigger? I'm gonna put 3" stacks on my '80 F-100, is why I ask. Al
Old May 27, 2008 | 10:22 AM
Sycostang67
Originally Posted by 80F100man
Syscostang67,
5" i.d. they were on sale when I got them so they were cheaper than the 4" stacks.
Old May 27, 2008 | 10:42 AM
redipsweb's Avatar
redipsweb
The cabs are all the same from 80-96, if it's a ex-cab the side window changes in 92. The wheel openings on 80-86 is more squared as where the 87-92 is rounded. I believe if you put the new (87+) clip on the older (86-) you have to also change the cowl panel where your wipers are at because of the hood line especially if it's 92+ front clip.
Old May 27, 2008 | 03:18 PM
80F100man's Avatar
80F100man
I have a unique question here, maybe someone can answer, didn't want to start a new thread tho'. Will the Dual headlights (the over & under ones) from a Ranchero fit into the headlight & turn signal cavity of my '80 F-100 if I put the turn signals somewhere else? And just what yr. Ranchero was that? Anybody know??
joelmopar
Ford Truck Parts for Sale
Jun 23, 2016 08:29 PM
joelmopar
Mar 18, 2016 08:52 PM
Outlaw56
Nov 1, 2013 11:28 PM
4rdnut
May 13, 2011 04:53 PM
hpcbmw
Dec 23, 2009 01:31 AM
