Oil Cooler
Old May 18, 2008 | 05:47 PM
heathrunkles's Avatar
heathrunkles
Oil Cooler
My oil cooler is leaking bad(rusted through) I found this on ebay and just wanted to make sure that ford only had the one for the 7.3(94.5-03). Also besides messy how difficult is it to change out? And I would asume that a need a gasket kit for the change out-anyone know where to get one? Thanks. eBay Motors: 7.3 Diesel Oil Cooler,Heater,Filter Housing,powerstroke (item 220235673506 end time May-22-08 17:36:45 PDT)
Old May 19, 2008 | 08:21 AM
Action4478's Avatar
Action4478
Thats what you need ....good price too...
Drain the oil & water ...I raised the left side of the truck a bit ,,,to help get enough fluid out to lower the truck & not have any leak back out ,(my block drains are too rusted to remove )used long extentions to get at the front header bolts through the fender well...The hardest part was to install the front header gasket....you may want to glue it to the cooler before installing it...
I left the oil drain plug out ,till I was finished, In case any coolant got in the pan ...
Old May 19, 2008 | 08:29 AM
MADVAN's Avatar
MADVAN
X2 with what Rick states.
BTW- E and F series coolers are not the same.
Bill
Old May 20, 2008 | 01:46 AM
Joe_D's Avatar
Joe_D
Just did mine on Saturday. It seemed pretty daunting at first but once I got in there I was able to wiggle it out, rebuild it, and put it back in. I would put a couple of plastic shopping bags over the ends so that you don't have any dirt or junk get in there when you are putting it back in. Remove them after you get it into position and are ready to bolt it back on. It worked great for me. I didn't have to jack up the motor or undue motor mounts or anything to get it out. About the only thing in the way is the fuel lines but they are easy to work around.
