clearance. for pushrods?
Old Nov 11, 2001 | 11:54 PM
kyla64's Avatar
kyla64
after reading the "292 tune up specs" i found alot of usfull info. one thing i am not quite sure on is i was taught to tighten the lifters untill rattling ceased it this completely wrong or just not for the yblock. if its not right how am i supposed to get .019"
also what was the original colors for the 64 292. i read alot of these post but dont quite understand the lagistics of it all.
Old Nov 12, 2001 | 10:57 AM
Rosati's Avatar
Rosati
Post clearance. for pushrods?
Y-blocks use solid lifters. If you zero out all lash, when the engine warms up your valves will not close and you will burn them. Adjust them cold to the numbers you found already.
Krosati
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/index.html|My Homepage]
My friends say I'm too old to play with toys.
I need new friends
Old Nov 29, 2001 | 04:03 PM
phjbbu's Avatar
phjbbu
>of it all.
I've got the same question on the engine color(s). If you find anything, please let me know. Kinda soon (a couple of weeks) as mine is out getting rebuilt. Eickman's book (see below) discusses paint schemes on pp. 44-45, but it's not specific and does not include info for post '59 versions.
On the valve thing, according to J. Eickman's book (The Ford Y-block Origin, Maintenence, Rebuild, 1984, Motorbooks International, Osceola, WI, 54020), page 76-77, "the preliminary valve lash specifications for both intake and exhaust valves is 0.020 cold and 0.019 hot. If you have a supercharged 312 with the high-lift camshaft, set the intakes to 0.022 cold and 0.020 hot and the exhausts to 0.027 cold and 0.025 hot." Oh, one more thing...on p. 33, he lists hot lash for '60-62 models as 0.018
Hope this helps!
Old Nov 29, 2001 | 05:16 PM
BlueOvalRage's Avatar
BlueOvalRage
