Sponsored by: Auxito
Gearing Time
Old May 18, 2008 | 03:26 PM
triton54's Avatar
triton54
Gearing Time
Ok so I have been contemplating gears in my 97 F-250 4x4 LD (7 stud) for some time and after a plethora of problems I can say it's time. My question to yall is this, when i shop for 4:56 gears i search for the ones for a 10.25 rear end thats a given depending on my choice of brand etc...now for the front, does it still stand that i go one lower, 4:55's? and if so what front differential do i search for? I have the 5.4 liter if that matters btw. Anyway hope to find the info i need and if you all have and manufacturers in mind i'm open to suggestions.
Old May 18, 2008 | 09:41 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Your front diff is a Ford 8.8 IFS. It uses Reverse Cut gears
Make sure your front and rear gears match. There are no such thing as 4.55's or 4.57's
Old May 19, 2008 | 05:01 PM
triton54's Avatar
triton54
I've just been told that in earlier years the front was one lower I would rather be stupid on here than to someones face lol thanks for the input.
Old May 19, 2008 | 09:07 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, some of the older trucks had different gears. 4.10/4.11 or 3.54/3.55 or 3.08/3.09
Don't really know why they did that...maybe certian gears weren't available for certian axles...so they matched them as close as possible.
The difference between your front and rear tire pressures will impact your gearing more than a .01 difference in gears. As long as you dont run 4WD on the pavement, you'd be fine
Old May 20, 2008 | 12:19 AM
LxMan1's Avatar
LxMan1
They did that so that the front would pull just a little more than the rear. Odd, but true.
Old May 20, 2008 | 10:25 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Probably to help turn those big tanks they built back then
