Coolant flush
Old May 17, 2008 | 03:01 PM
King0581's Avatar
King0581
Coolant flush
Finally got around to doing the coolant flush and installing my 203* thermostat. I only got about 5 gallons out when I drained the radiator and then got a little bit more out of the block drain on the driverside. I couldnt get the block drain on the passengerside to turn so I left it. I then pulled the thermostat and put it back together without the thermostat. I filled it up with well water and run it a while. Not sure how much came out when I drained it that time, so then the thermostat neck was leaking so bad I just held the water hose to it with the truck running for about 5 mins and I had clean water coming out(with no thermostat). Then I put the new thermostat in and filled it with distilled water and it would only hold 4 gallons. Then I run it for 30mins probably and drained it and filled it with 4 gallons of antifreeze and 2 gallons of distilled water. So my question is should I be ok? I also installed the fitting for the bypass filter and ran the line for it but I havent installed the filter yet(ran out of time).
Old May 17, 2008 | 05:53 PM
Benny2002's Avatar
Benny2002
Should be good to go, what kind of coolant did you run?
Old May 17, 2008 | 09:22 PM
King0581's Avatar
King0581
Fleetrite ELC.
Old May 18, 2008 | 07:53 PM
Benny2002's Avatar
Benny2002
You'll be fine, thats how kris(strokin) does it I think
Old May 19, 2008 | 08:15 AM
Wieckster's Avatar
Wieckster
I am going to do mine real soon I have all the stuff for it as long as you get 4 gallons of coolant in its all good RIGHT?
Old May 19, 2008 | 10:50 AM
brnab1's Avatar
brnab1
Im not sure about the 4 gallons i thought it took 32 Quarts which would be 8 gallons... bump
Old May 19, 2008 | 11:28 AM
Wieckster's Avatar
Wieckster
the 4 gallons is the coolant and 4 gallons of distilled water?
Old May 19, 2008 | 08:42 PM
John7894's Avatar
John7894
Mine only took around 6 gallons and that was forcing it. I pulled both block drains and the radiator drain and pointed the nose uphill and downhill to get as much out as I could. I used the 50/50 premix of Rotella ELC.
I think you'll be fine.
Old May 19, 2008 | 09:57 PM
rbaker6336's Avatar
rbaker6336
this is why it's not a good idea to use premix
after flushing you can add 4 gallons of full strength and top off with water and have 50/50 mix
you have 75% the coolant you need
