Relay Identification
Old May 17, 2008 | 12:45 PM
rbaker6336's Avatar
rbaker6336
Anyone have a schemetic of the power distribution box for a '92 F-150 or E-250
I need to know which fuses and relays do what
thanx
Old May 17, 2008 | 10:00 PM
Animalistic's Avatar
Animalistic
Check the top sticky post "Read First: 1987 to 1996 Tech info ". It should have what you are looking for.
Old May 17, 2008 | 10:11 PM
rbaker6336's Avatar
rbaker6336
the link I thought would be the one I need does not work and the one for 95 is different
Old May 17, 2008 | 10:17 PM
Animalistic
You are correct. The link "Engine-compartment Fuse Panel Layout " does not work. Not too sure if this would help or not. If you are not able to find the info in a search, you may need to pick up a Chilton's. It is worthless for troubleshooting but for spec's , it can't be beat.
Old May 17, 2008 | 10:28 PM
rbaker6336's Avatar
rbaker6336
I have searched on here for a number of hrs and everywhere else I can think of,and the chilton is worthless on this one
Old May 17, 2008 | 10:38 PM
Animalistic
You may want to PM either numberdummy or quicklook2. They have way more knowledge then I do.
Old May 18, 2008 | 06:32 AM
adrianspeeder's Avatar
adrianspeeder
The Haynes manual has it with great detail. Using it currently to pick apart a junkyard harness for use in my '79.
Adrianspeeder
