Code 32
Old May 17, 2008 | 08:06 AM
dragonslayer's Avatar
dragonslayer
Code 32
Code 32 flashing on the dash of `94 F-150 isn`t that dealing with the airbag sensor?
Old May 17, 2008 | 06:07 PM
dlburch's Avatar
dlburch
EVP circuit has intermittently failed below minimum voltage of 0.24 volts...
Ford Fuel Injection » 2 Digit Self-test Codes 11-32
Old May 17, 2008 | 06:26 PM
nitro94's Avatar
nitro94
Driver airbag resistance high. Most likely cause is the clockspring,.
Old May 17, 2008 | 09:48 PM
dragonslayer
I was wondering about that spring. I had my steering wheel lock up on me today and had to force the wheel to turn. Took the wheel off and found the spring all smashed.
Old May 17, 2008 | 10:25 PM
nitro94's Avatar
nitro94
The clockspring ( electrical coil of wire that turns with the wheel) is the wiring cartrage right under the wheel that connects to the air bag on top and goes down the column to the main harness.
Old May 17, 2008 | 10:33 PM
dragonslayer
Yes. I am going up to my mothers tommorrow to clean up her place from the ice storm over the winter, planning on getting one through StanBoo`s Ford on monday.
Old May 18, 2008 | 12:07 PM
fordnut1985's Avatar
fordnut1985
You can acctually pick them up thru most auto parts stores
Old May 26, 2008 | 09:45 AM
dragonslayer
Well life is fun had more damage inside than I thought some how a pin got ahold of some wires inside and broke the connectors for the speed control so had to change all of that to. All is back together now.
Old May 26, 2008 | 04:28 PM
nitro94's Avatar
nitro94
Thats good news
