Some simple alternator amp question.
Old May 16, 2008 | 02:38 AM
archangel's Avatar
archangel
Well, there is a site that has these high powered 200 amp alternators used in their under hood welding system.
Well, I have two 12V alternators out of Corvettes that are listed on the case at 120 amps, so I will assume each has 120 amp potential.
If I wire them both up to run like stock I should still have 12V with the potential of 240 amps, right?
Let's say you have two, 12V batteries both rated at 800 cca.
Wire them in parallel, you get 12 volts and 1600 cca.
Wire them in series and you have 24V and 800 cca.
Also, you could take a 24 V truck alternator and wire it up to two 12 V batteries in series and wire everything off one or the other battery at 12 V.
Not that I am setting up a welding system right now.
Any thoughts?
Old May 16, 2008 | 07:34 PM
Franklin2's Avatar
Franklin2
Try to avoid the situation of putting all the load on one battery if you can help it. With two batteries in series, it's best to run them both down at the same rate. It's actually possible to run one battery completely down, and then when it's hooked to a load in series with another battery, the charged battery will flow current through the dead battery, charging it backwards, reversing the polarity of the dead battery.
Old May 16, 2008 | 08:31 PM
archangel's Avatar
archangel
I was focusing the question on the dual Alternators and was just mentioning the batteries as a voltage and amp reference.
Old May 17, 2008 | 10:18 AM
Franklin2's Avatar
Franklin2
I see no issues with anything else you mentioned.
