Sponsored by: Real Truck
output speed sensor
Old Jun 26, 2016 | 12:35 PM
  #31
scpenner's Avatar
scpenner
Originally Posted by marty722
I have been doing alot of research on my problem. First thing that would happen is the OD light on the shifter would start to blink. Then it seems that there is no power although the rpm's go up and the eng seems fine but the trans seems like it moves real slow and misses. Then the check eng light comes on and reads the error code of p0720. Ok have replaced the sensor that the error code tells me to replace but now it happend again. As stated before I have done some research on the blinking OD light and it seems that when that has happen most of the people that this has happen to had to replace the transmission. Can any of the ford experts tell me what is going on with the blinking OD light? It says in the owners bood to contact ford right away. I have a 32 ft bounder that has 13,000 miles but it's out of warranty. I would really hate to have to spend the money to replace the trans, Any input would be great. Thanks
Marty
Hi Marty... I am having the exact same issue you describe. Did you find a solution?... would be highly curious and very greatful!...vehicle hits the shop Monday (tomorrow) .... hoping it can be fixed with sensors.
hamiltonfighter
Jun 13, 2024 03:38 AM
RTT
Jun 15, 2017 06:36 PM
mshawn78
1997 - 2003 F150
Mar 7, 2017 07:59 PM
k5jvc
15
Feb 25, 2017 04:26 PM
Tmarks4323
May 18, 2016 08:26 PM
