bent axle
Old May 15, 2008 | 08:28 PM
nintey4f150's Avatar
nintey4f150
bent axle
well i just swapped a lightning rear into my 94 f150 and took it around the block to find out that it has a bent axle.....so saturday morning i woll be swapping axles.... just wanted to know what gear fluid to use for a limited slip 410 rear
Old May 16, 2008 | 08:21 AM
Lazy K's Avatar
Lazy K
You will need EP80W90 gear oil plus the limited slip diff. additive. You can also buy the same oil with additive already mixed in.
Old May 16, 2008 | 08:56 AM
trgrhappy's Avatar
trgrhappy
You'll need about 3 quarts of lube ,give or take a few ounces, as well as the additive/friction modifier. I used just shy of the 3 quarts and a pint of modifier when I rebuilt the rear carrier in my F-150
Old May 17, 2008 | 09:44 PM
nintey4f150
well i swapped out the axle today and it went pretty good.... and going from an open rear with 308s to a posi rear with 410s is quite a difference
