Sponsored by: Auxito
starter noise
Old May 15, 2008 | 07:56 PM
dantsg's Avatar
dantsg
starter noise
I have noticed that when cranking the truck when cold there is a loud noise like metal to metal. This only happens when cold.
Any ideas?
Old May 15, 2008 | 10:09 PM
sbclemens's Avatar
sbclemens
Check your oil level. What type of oil are you using?
Old May 15, 2008 | 10:57 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Check the bolts on the starter to make sure they haven't backed out any. Ford also uses a flexplate between where the trans and engine bolt together (I'm not sure if they still use it on the new trucks...but I know they did on the older stuff). If it has one, make sure that's in good shape. Check your exhaust/heatshields for any looseness that could cause the noise.
