'60 292 Y... will it ever perform.?
Old Aug 2, 2002 | 09:38 PM
odlib's Avatar
odlib
I posted this in the 48-60 forum,.. but I think that was the wrong place.. here should be better.
"figure this should get a few hits...
Is it possible to increase the performance on a 292? I have a 1960 F500,.. and she don't do hills too good..... it'll get there (pullin a Steam Roller if necessary),.. but don't be in a hurry.
Any, I repeat,.. ANY advice would be appreciated. Can you get headers.?? what intake.?? Tuning.?? anything... at this point,.. $$ is not an issue.. I'm looking for the possiblities.
I'm not too excited about changing engines, not totally out of the question,.. but like the unique of the 292.
Thanx in advance for all your help. "
Old Aug 2, 2002 | 10:52 PM
pcmenten's Avatar
pcmenten
[updated:LAST EDITED ON 02-Aug-02 AT 11:53 PM (EST)]So, maximum torque is the goal. If you're gonna be rebuilding the engine anytime soon, make sure that you get a zero deck height and .035" head gaskets or some combination that gets you .035" of quench. Some head gaskets are .048" or so and that would require a +.013" deck height. Many machine shops won't even attempt to do this so you'll need to go to a machine shop that specializes in race engines. Keeping the quench to a minimum helps keep the compression ratio up, reduces detonation, and improves the burn.
I'll be using hypereutectic pistons with no valve notches in a 292 rebuild currently in progress.
I'm using the original heads on this 1956 engine, but I would have preferred the ECZ-G heads for their superior chamber shape. Good quench and good swirl from what I hear.
John Mummert has a selection of camshafts. And you may want the 1.54 rocker shaft assemblies from 1956-1957.
Pertronix, or better yet, Pertronix II ignition. The II ignition adjusts the spark intensity depending on load, etc. Saves the plugs when you're cruising by turning down the spark, but delivers a hot spark when you've got the pedal mashed to the floorboards.
I'd use a cast iron intake in your application; better atomization of fuel due to better heat retention. 4bbl for sure. Holley carb.
Keep the temperature at 195 degrees; less friction between aluminum and iron at that temperature then at lower temperatures. I use synthetic oil for the reduced friction, better resistance to breakdown when hot, and better detergent properties.
Don't get crazy with the exhaust system. Small pipes for a small engine will get you better torque.
And maybe dyno-tune it?
Old Aug 6, 2002 | 08:19 PM
pcmenten's Avatar
pcmenten
F250racer
Jul 7, 2009 03:51 PM
tutone
New Member Introductions
Feb 16, 2007 11:20 PM
aussie1
15
Oct 31, 2006 08:27 AM
OldSchoolRodz
May 5, 2005 03:26 PM
pcmenten
18
Dec 23, 2004 01:33 AM
