Trans.
Old May 15, 2008 | 02:13 PM
just-n-time's Avatar
just-n-time
Wink Trans.
Looking for a four speed out of a Torino or any other heavy car that was bolted to a 429. I have a 460 project in a 64 that I would like to install it into.
Old May 15, 2008 | 03:57 PM
85e150's Avatar
85e150
That would be the Ford toploader. You can scour the yards for one that will pop out of gear, or pay up.
complete trans/parts/tons of info:
David Kee Toploader Transmissions, Inc.
parts:
Toploader 4 Speed Transmissions
Catalog
more info, and advice regarding used boxes (easy to get over $1000 fixing a junker)
Buying Used Toploaders
google "4 speed toploader" for those and more.
BTW, the later model 4 speed OD toploader is built on the same pattern, but is not as strong. No way the OD will hold up to a big inch motor.
You will also want to be sure to get the wide ratio, 2.78 first gear box.
Old May 15, 2008 | 05:58 PM
just-n-time
I was thinking of the 2.20 first but 2.78 is great
Old May 15, 2008 | 07:11 PM
85e150's Avatar
85e150
Well, if you want the CR, go for it. Mighty tall for a heavier vehicle imo.
