Wacky Speedometer
Old May 15, 2008 | 09:53 AM
gvandyke's Avatar
gvandyke
Wacky Speedometer
Yesterday afternoon when leaving work, my speedometer stuck on 0. It did not register any speed. It then jumped and pegged on 100. Stoped the truck and it stayed there. Started moving again and at about 45 MPH (read on DashHawk) it went to 70. Moved back and forth like this for a while then seemed to reset and work properlty for awhile the jumped to 100 and started all over again.
Going into work this morning, it stayed on 100 and 70. I know the seed sensor and ABS controller are working as I see my speed on my DashHawk. No DTC at all.
Any help would be much appreciated.
Old May 15, 2008 | 10:30 AM
Sarge261's Avatar
Sarge261
There have been issues with the clusters, I have read before. The fix is to have either the speedo or the cluster replaced.
Sarge
Old May 15, 2008 | 10:59 AM
cdkell's Avatar
cdkell
I had the same problem the tach quit working also. the dealer replaced the cluster.
Old May 15, 2008 | 11:16 AM
Tungsten's Avatar
Tungsten
Easy check first:
Crawl under the truck. Locate the Vehicle Speed Sensor (VSS) harness coming out of the transmission. Make sure it's snapped together securely. Re-test your speedometer.
I had this happen to my truck a while back and it was just a loose harness.
Old May 15, 2008 | 01:11 PM
gvandyke's Avatar
gvandyke
PHP Code:
Would this not also effect my DashHawk as it is pluged into the OBD2 port and shows my speed? This is why I think it is the cluster. How much am I looking at as it is out of warrenty?
Thanks for all the replies.
Old May 15, 2008 | 02:33 PM
Tungsten's Avatar
Tungsten
My apologies. If the Dashhawk is still showing the correct speed, then the computer is getting the right information from the VSS.
Old May 15, 2008 | 04:56 PM
gvandyke's Avatar
gvandyke
Before I left work, I did the diagnostic feature in the odometer. The first thing is gages. The speedometer moved up from 100 to 70 then back to 100. I left it sit like that in that mode for a little longer and all of a sudden it went to 0 and functioned correctly all the way home. Seeme OK now. The cluster is $281 plus $300 core.
Thaks all.
