88 ford wiring problem
Old May 15, 2008 | 08:31 AM
tooblue's Avatar
tooblue
I have an 88 ford 7.3 idi. I pulled up to a gas station the other day and it just died. Turn the key and nothing. Things that dont work, winshield wipers, blinkers, windows, glow plugs, ingnition. The only way i can start it is to run a hot wire from the battery to the injection pump and bump the starter siloniod on the fender. What wires could of burned? All help is appreciated!!
Old May 15, 2008 | 06:45 PM
gene17847's Avatar
gene17847
the first place i would look is by ur right battery there is fuseable likes there
Old May 15, 2008 | 08:43 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Look for the yellow wire circled in the picture.
Behind the passenger side battery near the voltage regulator.
The grey connector may look like it has been overheated, if that is the case, you will probably have to splice the wire around the connector.
Old May 16, 2008 | 09:41 AM
tooblue's Avatar
tooblue
I smelt burnt wires from inside the cab as soon as the truck died. Could it be anything to do with ignition? I pulled the air cleaner off and notice the glow plug silonoid is burnt. Maybe that has to do with burnt wires. I just dont understand how the motor dying make no gauges work, windows dont roll up, no winshield wipers. Thats why im thinking its the ignition. Maybe the rod isnt pushing the switch that tells it to come on. No glow plug light either.
Old May 16, 2008 | 12:17 PM
tbone91's Avatar
tbone91
Do your headlights work?
Old May 16, 2008 | 07:48 PM
Dave Sponaugle
That yellow wire in the picture is main cab power from the battery.
No power, electrical items are not going to work and the engine will not run.
allen66
Modular V8 (4.6L, 5.4L)
Aug 13, 2015 11:59 AM
welpracing
Nov 5, 2012 02:15 PM
oleman
Electrical Systems/Wiring
Nov 30, 2010 10:35 PM
mreggball
Nov 30, 2006 06:08 PM
88grandmarquis
Dec 1, 2002 10:21 PM
