360 to 460 swap
360 to 460 swap
I have a 1970 F100 2wd with a 360ci and a c6 and A 1975 F150 2wd SC with a 460 and a c6. will the 360/c6 unbolt from the frame and the 460/c6 rebolt in its tracks. If any one has done this please post. I think the 3 mounting **** on the FE blocks and the 385 blocks are the same and the rear tranny mount I think is in the same place? The 75 looks to have a little more hi tech engine mount setup
I just did this swap in a 76. This swap requires new motor mounts and towers. According to Ford racing, if you are building the motor, you ehter need to put turnbuckles on the motor to keep it from break the stock mounts, or use the L& L mounts. The C-6 moutned right up to the exiting mount from the NP. You may have to have the drive shaft trimmed depending on the tailshaft on the C-6.
He didn't hint that he was building a fire breathing engine so the Ford Racing info doesn't hold much water either. IMHO
John
