Here is my truck now.. 86 f-150 six inch lift plus 3 in body. Both of which will get removed this weekend. Still need to finish the 302. I bought it with the 3 inch body then put the 6 inch in after the motor blew. So I have never driven it yet and I already want to SAS it.
Are there any mud racers on this site? The only mudding event we have around here is a mud drag. I can't decide on gears. The truck will have a 302 HO gt40 heads mild cam. Not much you can do with speed density. I'm trying to get the gearing down so I can start in 3rd gear low range. I'm thinking without a big block that probably won't be possible? Guessing with my SB I'm stuck with either 5.13 or 4.88s?
