1959 292 Y Block Question
Old Dec 2, 2002 | 10:50 AM
DGM55's Avatar
DGM55
This may sound like a silly question, but do all the Y-Blocks have the same firing order and cylinder numbering sequence? The reason I ask is because I have 1959 292 per the casting numbers that I'm rebuilding and I guess at one time the engine had been rebuilt, but the connecting rods are out of order based upon my knowledge of the Y-Block. The number 1 connecting ROD is in the last hole on the left bank if you are looking at the front of the engine. So basically the connecting rod sequence is 1234 on the left back starting at the back hole and going forward. So looking at the front of the motor, the connecting rod sequence is 4321. The right bank is correct. Just wanted to make sure that they did not change this up at some point.
Casting number is B9AE 6015 F
1955 F100
Thanks
Old Dec 2, 2002 | 07:53 PM
286merc's Avatar
286merc
Nope, they never changed.
Guess the rebulder had a hangover that day.
Old Dec 4, 2002 | 01:24 PM
phjbbu's Avatar
phjbbu
ScallyWaggler
Apr 9, 2026 12:58 PM
Eric Needs Help
Jan 4, 2016 08:40 PM
jaggermk
Jun 1, 2015 08:12 PM
transam525
Mar 30, 2015 05:27 AM
Roonz '59
Feb 15, 2015 02:12 PM
