Headers
Old May 13, 2008 | 11:04 PM
DixieOffroad89's Avatar
DixieOffroad89
Headers
im installing new headers on my truck this weekend. just wanted to see if anyone has any thoughts on how hard of a job it will be. single cab250, 460, 28 inch lift
Old May 17, 2008 | 10:23 PM
shadow_trucking's Avatar
shadow_trucking
pretty easy. especially if it is lifted that high. hardest thing you have to do is weld collectors to pipes.get the drop in gaskets. start front and back bolts then drop in exhaust gasket. when you put the collectors together put 2 metal gaskets per side and use locking nuts to fasten will keep from leaking. have fun....
ps.......... dont forget to retighten header bolts every 100 - 200 hundered miles for the first 500 to insure they stay tight.
Old May 17, 2008 | 10:48 PM
95F350XL's Avatar
95F350XL
The hardest part is prob getting ontop of the engine bay to put them in. You can prob stand under the truck and put them in.
Old May 17, 2008 | 10:53 PM
Animalistic's Avatar
Animalistic
With 28" of lift, I imagine you could do about everything from under the rig. What keeps it from fliping over?
Old May 17, 2008 | 10:54 PM
95F350XL's Avatar
95F350XL
Tires that are as wide as my truck, caterpiller tracks? We got to see a pic of your truck. Post it up.
Old May 19, 2008 | 10:01 PM
DixieOffroad89
pics
Old May 19, 2008 | 10:47 PM
lawpowerstroke's Avatar
lawpowerstroke
Where do you get headers for a 96 f250 460.. i've seen very few but they also ask something about Egr or smog pump stuff.. do you get the set without any of that? what do you get for that. does it have a smog pump you can take off?
Old May 19, 2008 | 10:56 PM
DixieOffroad89
i would try summittracing.com thats were i got mine. i am going to remove the smog pump and everything assoc. with it. im just going to run straight pipe to glasspacks and dump it behind the cab.
Old May 21, 2008 | 12:46 PM
jarod17's Avatar
jarod17
As well as summit racing you can get a set from Bank Power. Yes they do make things for gas trucks to. PAW also has a lot of 460 truck stuff.
Old May 21, 2008 | 07:36 PM
Dustin1690's Avatar
Dustin1690
What a beast holy moly
Old May 21, 2008 | 10:13 PM
Raider50's Avatar
Raider50
I must say, that truck is super bad ***. Im supprised you could even but plates on it its so cool, excellent truck man.
Old May 23, 2008 | 04:38 AM
bradshaw6243's Avatar
bradshaw6243
Old, but not too old
How do you keep from getting hurt getting out of that truck?
Old May 23, 2008 | 06:23 AM
86F150302's Avatar
86F150302
