94 TD stsrting problems
Old May 13, 2008 | 08:30 PM
factoryone's Avatar
factoryone
Hey all,
I got a starting problem with my 94 TD. About one month ago after sitting
in the garage for awhile the truck wouldn't start. It had been leaking fuel
occassionaly at the fuel pump. I went ahead and installed the new fuel
pump and a new starter while I was under there. After the install Iin a
timely fashion slowly achieved fuel at the schrader valve bleeding off the
air each time (changed fuel filter also, filled with diesel-kleen). The truck
Started faster than it ever did. However it is know longer. The truck is my
toy project, so I don't drive it currently, I noticed that the injector caps
leaking so I ordered the o-ring kit I just didn't install them yet. It leaks
fuel pretty bad at the right rear of engine. After installing all of the above
The day after running the truck, it would start then quit and act as if it
were flooded hold pedal too floor and it would start. Now that won't
work doesn't even want too fire. It is getting fuel (and air) at the schrader
valve. Could it be the injector caps leeking down causing air intrusion
problems.
Any suggestions would be appreciated
thanks, Mike
Old May 13, 2008 | 09:27 PM
George D.'s Avatar
George D.
Did you change the caps and orings? Also did you change the lines between the caps? They can crack or dry rot and let air in. Holding the pedal to the floor wont do anything a diesel cant flood like a gasser. If you are getting air at the shrader you also may have a small hole in the lines running from the tanks to the lift pump.
Old May 14, 2008 | 12:23 PM
tbone91's Avatar
tbone91
If you've got all the air purged out, and then you get any air at the schrader valve after letting it sit, then you're getting air in somewhere.
It could be just about anywhere in the fuel lines. The most likely is the o-rings/caps/return lines. It could also be the steel lines going to the fuel tanks. Look carefully at clamps, joints, frame attachment points. There could also be a leak in the lines inside the tank. How much fuel do you have? Especially if less than 1/3 - 1/2 tank, try switching tanks and/or parking facing downhill.
The fuel filter and/or water separator may be leaking.
Also, if you've done a lot of cranking, your batteries may be down. Diesels need to turn over fast to start. If you can count the revolutions, it's too slow.
Be careful to not crank more than 20 seconds and then wait at least two minutes before trying again to avoid starter damage.
Good luck.
TheBlueMule
Apr 11, 2014 10:50 AM
TheBlueMule
Mar 28, 2014 10:21 AM
oldblue89
Jan 12, 2012 07:57 PM
artfd
Jan 1, 2012 08:13 PM
tomph
Jul 11, 2010 10:04 AM
