Setting the timing question!
Old May 13, 2008 | 07:57 PM
Dre82s's Avatar
Dre82s
Should the timing be set when the engine is warmed up, or while still cold? and where in the marking should I be O, 10 ir what?
Old May 13, 2008 | 09:06 PM
quicklook2's Avatar
quicklook2
warm, spout out, 10 degrees btdc.
Old May 14, 2008 | 12:35 AM
BeufordTJustice01's Avatar
BeufordTJustice01
Hi,
The engine should be warm, remove the SPOUT connector, set the timing to 10deg BTC then replace the SPOUT
Old May 15, 2008 | 11:15 PM
Dre82s's Avatar
Dre82s
and where is the Spout Connector? cause I am just hooking up the timing gun to my # 1 cylinder
Old May 16, 2008 | 04:47 AM
EPNCSU2006's Avatar
EPNCSU2006
What year is your truck?
