1978 - 1996 Big Bronco
clunk when breaking
Old May 12, 2008 | 08:29 PM
RA81222's Avatar
RA81222
clunk when breaking
I put right side ball joints on my 93'(first time I tried this job and hopefully the last) and all seemed to go well and I don't think I screwed anything up, but now when I get on the breaks and stop alittle hard I hear a clunk.It is hard to tell where it is coming from.Gradual breaking does not make it do it.Problem was not there before ball joint job.Not sure if having a tight front end is revealing something else now that has wear?Sound kind of remines me of when my radius arm bracket and bushing went bad.Any thoughts?
Old May 12, 2008 | 09:28 PM
b4hntn's Avatar
b4hntn
Grease the slip joint in the middle of the rear driveshaft.
Old May 12, 2008 | 10:06 PM
cajunland's Avatar
cajunland
Sounds like your radius arm bushings. I assume you changed them too. Doulble check that they are tighten to proper torque specs.
Old May 13, 2008 | 05:15 AM
RA81222's Avatar
RA81222
Greased slip joint in past when it was clunking and yes bracket and bushings were replaced.
Old May 13, 2008 | 05:56 AM
b4hntn's Avatar
b4hntn
Hmmm....I'm sure more suggestions will come along.
Old May 13, 2008 | 08:41 AM
alxsnmr's Avatar
alxsnmr
Check the U-joints?
Old May 13, 2008 | 02:22 PM
RA81222's Avatar
RA81222
I will.Just odd that no clunk before the ball joint job?
AGrayson84
Oct 24, 2016 10:21 AM
okiemike
Jul 30, 2016 10:34 AM
pomial
Sep 22, 2015 01:50 PM
F0rdF0rever
16
Aug 12, 2008 08:09 PM
SaleenX
Jun 15, 2008 07:42 PM
