should i??
Old May 12, 2008 | 07:51 PM
mybigredford's Avatar
mybigredford
should i??
going to install my bellowed up pipes next week and i bought new turbo/pedisatl o rings, but as far as i know i dont oil leaking from there, i will of course change the turbo set, but if i have no leak you guys figure i should change the pedistal ones too while im in there even though they arent leakin??
also do i have to change the orings on the collector and the one on the spider part that connects to the turbo?
Old May 12, 2008 | 08:24 PM
DieselCamper01's Avatar
DieselCamper01
I am no expert but the only orings I remember from changing my pedestal were the ones on the bottom and the ones on the top. As long as your in there you may as well change them.
Old May 12, 2008 | 08:30 PM
Snopro's Avatar
Snopro
I would do the all 4 in the pedistal. and no need to on the x pipe.
Old May 12, 2008 | 09:17 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Trust me, it is alot easier to swing that 10mm wrench around if the pedestal is out of there too. Make sure to cover the holes. I myself made a tool out of flat steel, drilled two holes, and i bolt it back onto the block to cover up the holes.
Old May 12, 2008 | 11:49 PM
mybigredford
thanks guys
one more quick question, i have asked a couple times before on other threads but no response. when putting the new orings in, do i coat them with a little oil like when we change our oil filter or just put them in as they came out of the package and bolt it back up?
Old May 13, 2008 | 12:10 AM
Snopro's Avatar
Snopro
oil will help keep them in place durring the install, or some grease or vasaline. you dont want one to move on reinstall... i had one do so.. started teh engine and next thing i had 2-4 qts of sooty oil in my driveway.
shield1978
Dec 5, 2013 03:03 PM
snaponprofile
38
Feb 11, 2011 05:07 PM
MagKarl
Nov 1, 2010 11:00 AM
Duksrule
Oct 15, 2008 05:37 PM
Duck Hunter81
Jan 8, 2008 05:45 PM
