1st and reverse shifting problems????
Old May 12, 2008 | 07:38 PM
Pitchfork87's Avatar
Pitchfork87
for some reason my truck shifts very hard into 1st gear and actually grinds when i try to shift it in reverse. if any one has any comments or insight it would be greatly appreatiated.
1994 f-350 psd. 4:10 gears
Old May 12, 2008 | 11:20 PM
secondarychaos's Avatar
secondarychaos
i only know basics of the auto tranny, but my guess would be that you may have lost a planet carrier, or clutches...
I'm hoping im wrong!
Good luck, and welcome to Fte!
Old May 13, 2008 | 12:17 AM
scatgo's Avatar
scatgo
Before you get into the tranmission check the slop in the clutch pedal bushings mine had massive amounts of play and when I replaced them it made a big differance. Royal purpel ATF helped alot to. O yea our manny tranys use ATF.
PS You do have a manual trans right?
Old May 13, 2008 | 07:21 AM
Neal 97 250's Avatar
Neal 97 250
Mine has been grinding going into reverse alot lately. The clutch pedal has been fixed and it still does it. Any ideas. I just take it easy going in so as to extend it's life.
Old May 13, 2008 | 09:45 AM
MagKarl's Avatar
MagKarl
I've noticed that if I let mine idle in neutral for a while and then try to stick it into reverse that it will grind, especially if the trans is cold. But if I first try to stick it into first or second and then go to reverse it will not. I don't think R is synchronized, so there's nothing to help mesh the gears smoothly when everything is rolling in there.
Old May 13, 2008 | 10:45 AM
scatgo's Avatar
scatgo
Your right that reverse in not synked. I have never had a problem with grinding going into reverse but it would pop out unless I double clutch it. Do you guys have that problem to? The pedal fix and royal purple helped.
Old May 13, 2008 | 10:50 AM
secondarychaos
hmmm. i was thinking he has an auto...
??? more info !!
Old May 13, 2008 | 11:05 AM
MagKarl's Avatar
MagKarl
Scatgo, I don't have any troubles popping out of gear. I changed my axles, xfer, and transmission over to RP a few weeks ago, but didn't notice much change in the shifting. My rig has ~228K on it, so I'm sure the transmission is well worn. I'm thankful it still works.
Old May 13, 2008 | 07:52 PM
okfarrier's Avatar
okfarrier
More than likely if you are not losing any stroke because of slack in linkage or weak master - slave cylinder than you probably have a weak pressure plate that isnt fully disengaging .
Old May 14, 2008 | 12:47 AM
JCart's Avatar
JCart
Would suggest changing tranny fluid to Redline MTF did it in mine and has stopped the grinding on downshifts from 3rd to 2nd and also into R...
jrc
