Now i'm really confused!!! AC problems
Old May 12, 2008 | 07:35 PM
zarillus's Avatar
zarillus
Exclamation Now i'm really confused!!! AC problems
AC problem again replaced rear evap core, and accumulator but still no cold a/c after re-charge.Clutch on compressor fine no leaks no but still only small cooling from A/C.Blend door okay too
Air temp seems to be related that is blows colder if the air outside is colder.
Pressure high side and low side seem fine and within standards.
Any Ideas Condenser Maybe?
I'm not sure what is going on!!
I do still have a hissing sound from rear quarter panel and when i put my hand around the rear evap core it seems like it's leaking but dye does not spit out under uv light.
Any Ideas guys, i really don't want to take this sucker in the shop.It will be a billion dollars!!
Old May 12, 2008 | 09:37 PM
sbclemens's Avatar
sbclemens
You can try putting some dye in the system and look for leaks. Is the front air cold? What is the temperature of the incoming air in the front compared with the out side air? What are your low and high side pressures?
Old May 12, 2008 | 09:39 PM
sbclemens's Avatar
sbclemens
Try putting some dye in the system and check for leaks. Does the front blow cold? What is the temperature of the incoming air in the front compared with the outside air? What are your high/low side pressures?
Old May 13, 2008 | 06:10 AM
projectSHO89's Avatar
projectSHO89
What year?
What were the actual pressure readings, the ambient temp, and did you follow proper vehicle preparation?
Have you checked the fan clutch? Hit the condenser with the garden hose sprayer to see how it reacts?
Steve
Old May 15, 2008 | 02:36 PM
zarillus's Avatar
zarillus
45psi low & 300psi high
Ambient 80 degrees
Clutch operates fine
Old May 15, 2008 | 02:56 PM
projectSHO89
Ambient 80 degrees
Those pressures are wacked. With an 80F ambient (assuming no other faults), you should be seeing low side pressures down in the upper 20s and a high side pressure much closer to 200.
Investigate:
1) Overcharge.
2) Restriction in high side including the condenser
3) Dirty condenser or insufficient airflow through condenser (weak fan clutch).
I'd say either #1 or #3 is the most likely.
Steve
Old May 15, 2008 | 02:58 PM
dillinger's Avatar
dillinger
It's ALL about HEAT and TEMPERATURE!
This might help you out, a little long but alot of information.
I would almost say overcharge or a restriction.
Pikachu
20
Jul 22, 2015 08:18 PM
jaygotmilk
1997 - 2003 F150
Aug 26, 2014 06:23 PM
granny_rocket
Dec 19, 2013 08:38 PM
karlStolz
Sep 26, 2011 05:10 PM
Dannym
Jul 3, 2005 07:03 PM
