>I have an 86 F250 351W 4bbl.
>Does anyone know the exact HP
>and torque specs?
sorry that this doesnt answer your question, but I have one for you. Did your truck come stock with a 4bbl carb? I have a 1991 Crown Victoria with a 351w and a crappy 2bbl variable venturi carb that i want to switch to 4bbl, but want to do it for cheap.. I was wonderign if i could find old 4bbl truck intakes and carbs at a salvage lot??
I am not sure this will help either of you but heregos
The 1985,1986,and 1987 Ford 351W engines came with a highoutput package which consisted of
-Holley 4-barrel 4160 carb
-less restrictive muffler
-17-inch air cleaner
and someother equipment
Keep in mind that the hp and torque is with a jetterd down-emmision carb, EGR system, Smog Pump, Cat, Big-Quiet Muffler, retarded ignition, low compresion, and all the other junk that the goverment required but that doesn't help anything (even the environment).
>of -Holley 4-barrel 4160 carb -less
>restrictive muffler -17-inch air cleaner and
>someother equipment
do you happen to know what intake manifold was used on this truck? i see this swap going onto my car very shortly, if I can find one in a salvage yard.. my variable venturi carb is so out of tune my car wont even run.
First look into your local auto swapper for a used aftermarket 4bbl intake for a small block ford ($50 max). They are only about $100 new and give a noticeable difference in performance over stock(i.e. Edelbrock performer). Then call Summit or some other catalog and tell them you want a new 500cfm carb (holley or other). They'll ask you what it's for and just about tune it in for you. $200 bucks max for a small holley. Did it on my '77 f150 302. Only wish I would have used a smaller carb (i had a new 600 laying around). You won't regret going aftermarket in this situation.(my opinion) Good Luck!
Remember that the 351 has a different intake than a 302, the 351 is wider so you must specify that you have a 351W. Also I would recomend a 600 cfm, or higher if you use a cam and lower gears. I have a '84 Ranger with a 289 that now has a 750 double pumper, people say it is to big but I am getting better milage and much more performance than the 600 Edelbrock I had.
stock 351 H.O.=
Iron intake with square carb flange.
