bobdshr
Old May 12, 2008 | 02:39 PM
bobdshr's Avatar
bobdshr
Smile bobdshr
I have a 1960 F-6 with a 292 four speed with a 2 speed rear end. what gear oil should I use in the transmisson and the two speed rear end?thanks bobd
Old May 12, 2008 | 05:12 PM
4tl8ford's Avatar
4tl8ford
My automatic answer is 90 Weight Gear Oil, but I live in PA and would be driving it in all seasons.
In AZ the 90 Weight would work if you are only doing Cruses or Non-Daily use. More than that and I would go to a 130 or 140 Weight.
Old May 12, 2008 | 09:47 PM
Old F1's Avatar
Old F1
I think the electric two speed uses oil in it too, 10 weight. But I have been wrong before.
Old May 12, 2008 | 10:55 PM
Fomoko1's Avatar
Fomoko1
I`ve used ATF in my two speed assembly, I don`t know if that`s correct but that`s what I was told to use.....
Old May 13, 2008 | 12:55 PM
Old F1's Avatar
Old F1
Old May 13, 2008 | 02:41 PM
bobdshr's Avatar
bobdshr
Wink oil and gear lub
Thanks for your help. As I understand it I should use 90 min wt. for the transmission and ATF for the two speed rear end is that correct? Bobd
