Engine numbers
Old Jul 7, 2000 | 09:53 PM
mikescamping's Avatar
mikescamping
Engine numbers
I finally found the numbers on the block of my 302,they were above the starter.
They are D10E-6015-AA 1B25 Can anyone tell me what those number represent. If not where do I go to find out what those numbers represent.
Old Jul 8, 2000 | 04:54 AM
Bobs60F100's Avatar
Bobs60F100
Engine numbers
Mike,
There was a post on june 10 by Morky, about ID numbers and he got a reply that list numbers for 70 to 81 according to them you have a 70-74 302.
As far as the pully for the water pump, what I meant was that you should get a complete set from a non-power steering engine. The 226 pulley would only work if you have the same pulley as I have. My crank pulley is a duel pully with the outer pulley bigger then the inner pulley. And it isn't a perfect match there is about a 1/8 inch misalignment between the pulleys, but I want to get my truck back on the road so I'm going to live with it.
Old Jul 8, 2000 | 08:51 AM
mikescamping
Engine numbers
Thanks,
The information you provided has helped a lot.
Mike
Old Jul 13, 2000 | 06:48 PM
Pastmaster's Avatar
Pastmaster
Engine numbers
uscgrad93
May 10, 2021 07:40 AM
doug42190
Jul 20, 2016 03:15 PM
nowuryz
Nov 15, 2015 01:59 PM
70f250highboy
May 20, 2015 07:58 PM
NDrum2005
2004 - 2008 F150
Nov 7, 2006 10:00 AM
