tranny fluid low
Old May 11, 2008 | 08:05 AM
greenterror's Avatar
greenterror
Question tranny fluid low
how do i fill it up i have a dip stick can i use that
Old May 11, 2008 | 09:28 AM
sbclemens's Avatar
sbclemens
Make sure you check the fluid level properly:
1) Drive the car until the engine has reached normal operating temperatures
2) Park on a level surface and keep the engine running
3) Press the brake and move the shift through all the ranges
4) With the engine still running, pull the dip stick out, clean it, reinsert it, pull it out again and read it. The level should be in the x-hatches.
5) If you need to add fluid, put a funnel in the dip stick housing and add a small amount of the proper fluid. It only takes a pint of fluid to raise the level from the low to the high mark when the tranny is warm.
