6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Help, Engine wont start 6.4 (edge evolution)
Old May 10, 2008 | 10:19 PM
dino199's Avatar
dino199
I installed the "Edge Evolution" Chip four days ago into my 2008 F250 6.4 Litre. Everything was fine 24.8 mpg. Today, I change the setting from mileage to extreme. I did not wait to it was finished loading the settings, by accident. The motor turned over for 10 seconds and now it want even try to start or turnover. I attempted to reload the factory settings twice and would not let me do anything. I notice a anti-theft alarm flashing on dash. I even unhooked the negative side of both batteries for a hour with no sucess. PLease can anybody help, Technical support for edge will not be in till Monday.
Old May 10, 2008 | 10:58 PM
SUPERDUTY_untouchabl's Avatar
Wow that mileage is awesome is that hand calculated or by the lie-o-meter?
Old May 11, 2008 | 10:42 PM
iridesand06's Avatar
iridesand06
Sounds as though you may have somehow deleted the factory PCM program including the anti-theft key codes. If you are still unable to reload the factory settings/program or if Edge tech support is no help then I would remove the evolution completly and call the dealer just tell them the truck wont start. They can obtain the factory program for your truck and reflash the PCM and reprogram all your keys if nessesary. They may spend some time trying to figure out what happened though...
Old May 14, 2008 | 01:51 PM
mikejbayus's Avatar
mikejbayus
hope you have the truck running by now. i have one question can you program gear ratio size or is it just tire size with EDGE.
Old May 14, 2008 | 01:56 PM
dino199's Avatar
dino199
With the help of Edge the truck is up and running. I have only owned the edge for about a week and by far I am no expert. It does have a feature that prompts you to enter your tire size. I am unaware of anything regarding gear ratio that I have seen so far.
houzer
Feb 16, 2025 07:55 AM
08F250SD_Laredo
May 4, 2014 02:52 PM
greagin
Apr 8, 2007 09:28 PM
