Front end noise
Old May 10, 2008 | 01:14 PM
01PS's Avatar
01PS
Front end noise
My front end has been noisier lately, and I'm not sure what it is. I replaced the left hub/bearing assy about 20K ago and the right still feels tight as of this morning. I plan on doing the following soon, and would like to know what else should be done while I'm in there.
Brakes (pads/rotors/slide pins)
Ball joints
Needle bearing lube
Auto-lock hub lube
Oh, and can anyone tell me what this broken seal is? Thanks!
Old May 10, 2008 | 01:52 PM
jhand124's Avatar
jhand124
I struggle in this area and usually have my shop fix it for me (I'm getting screwed I think) but I digress. I guess it's the axle seal.
Old May 10, 2008 | 01:57 PM
big poppa's Avatar
big poppa
I would guess the same, axle seal. I did the rear on my wife,s expy and you have to pull the axle. Good luck on the seal change.
Old May 11, 2008 | 11:01 AM
01PS's Avatar
01PS
Maybe I'll let the shop do that one for me. I hate to do it since I'll already be in there, but I really don't want to hurt anything not knowing what I'm doing.
Old May 11, 2008 | 12:43 PM
new2diesel's Avatar
new2diesel
Yes,that is an axle seal/dust seal. I have an 02' with the same problem. I picked up new ones about a year ago and started to get into replacing them but found out you need a tool. My next door neighbor is a mech. and now has the tool, but I need more gumption to get it done. If you do it, and you have the vacuum lockouts, make sure you get new O-rings
Old May 11, 2008 | 12:46 PM
new2diesel's Avatar
new2diesel
I forgot to add that when I pulled it apart, everything was ok inside. The seal wasn't letting any poo-poo in.
Old May 11, 2008 | 02:46 PM
AustinS's Avatar
AustinS
What kind of noise is it you're getting?
Is it moaning, squealing, clunking?
Austin
