I'm guessing the fuel pump in my front tank took a dump. I was running on the front tank all day yesterday and stopped for a bite to eat. When I came back out, the truck would crank but wouldn't start. Front tank is about 1/2 full. Gauge works fine but I can't hear the pump prime. Switched to the rear tank and it fired right up.
I really don't want to spend a fortune on a new pump. Any good sources for reasonably priced OEM pumps or should I roll the dice on an aftermarket unit. This truck is not my daily driver. I primarily use for chores/hauling on the weekends.
Anyone happen to know the part number for the front pump?
RockAuto has aftermarket fuel pumps for your truck. Prices start at $106.79 and go upwards to $269.89. If you send me a message with your zip/postal code I can calculate shipping for you.
